Hi,
I have to replace old all season run flats ( Pirelli [email protected] - 205/45/17), and I am not sure if I should go with other than Pirelli run flats or change it to non run flats .... help me out.... pls
Thnak you:)
Canned
Pirelli [email protected] are not all-season tires. If you want all-season run flats, your only choices in 205/45-17 are Continental ContiProContact SSR and Goodyear Eagle RS-A EMT.
The cheapest run flats are Kumho ECSTA SPT XRP.
Thank you Miniac,
Since I got the car I have a problem with Pirelli tires, and to tell you the truth I am sick an tired of problem with NYC roads and run flats, do you think it is good idea to change to non run flats?
Can you recommend something ?
DSJ
Canned
If you switch to conventional tires you'll need to carry some sort of mobility kit (compressor, sealant and/or plugs) to deal with flats.
You might want to switch to a 215/45-17 size for more sidewall protection against potholes.
You can use the Tire Rack site to check availability, pricing and customer ratings of tires in the particular class (all-season or summer) in which you're interested.
