1 - 20 of 36 Posts
Deserter Zed
lambo doors will cost about £1500-2000 not a clue about tha reverse bonnet. sin this car a lot its an american show car. you best asking a body shop that specialises in custom jobs to av a luk at the bonnet, there is a kit u can buy 4 tha doors.
I think you could probably get the doors done for alot cheaper than that. It is just a case of special hinges and a bit of hydraulics................................saw it on pimp my ride on MTV.........seemed fairly easy! ;)
Deserter Zed
it is but people charge the earth for premade, no weld kits. if you do it custom it will be cheaper but not as reliable. having said that custom bodyshops will charge u a lot for labour!
Deserter Zed
apartently is no cutting, no welding, and totally reversable!!!!
gonna b around the thousand pound mark i think.
seeing is believeing thou innit, i'll wait b4 jumpin up an down!!
group buy ne1??? lol
Smoked said:
cum on then Leccy, this is where u step in!! ha ha ha master of tha group buy.
will post up wot replies i get.
Ben
lol. :D :D
I would definately be up for lambo doors :D
I think this could be your group buy though (seeing as it was you that got me started on these group buys), I need a bit of a break what with the forthcoming West Tuning group buy.
If the price were reasonable, I would defiantely be interested though.
Cheers, LB.
Deserter Zed
Leccy_Blue said:
lol. :D :D
Cheers, LB.
he he, ok ok. well i really cant afford this mod atm, but i wont let that stop me!! lol. wen i here bak. if there is enuff interest i will try an set up a group buy. failing that i'll try an jus set up sum nice discount 4 mini2 users lol.
Deserter Zed
thats tha type of kit im looking into, yes. i would encourage the use of 'universal' kits, as u generally av 2 du a lot of cutting and blah blah blah to get em 2 fit.
idealy i want mini specific, direct bolt on, fitable in a couple of hours, totally reversable, no need for a custom body shop to do it if your mechanically minded.
Ben
Deserter Zed
getting teh pneumatics and the actual hinge fitting look quite easy, the hardest part will b alligning the hinge i think, for a factory door seal. take you time and i cant see it being a problem thou, if using a decent kit. (bin lukkin thru a step by step for a celica)
Ben
1 - 20 of 36 Posts
