Changed high pressure diesel fuel pump on my clubman solved the problems I had but pump I fitted is making a sound like a dry bearing only when car warms up is the pump u/s or is there a remedy
have you over tightened the cam belt slightly,, there is a spring tenioner and a arm and must be set to the mark for correct pressure, right special job as well replacing that pump
