Not turning over N47 - after doing timing chain R60 Countryman
1452 Views 2 Replies 2 Participants Last post by  feldo
My Mini isn't turning over after I removed the engine and timing chain.
Starter was smoking.
However once or twice it turned over just slowly(battery was likely not at 100%)...and I can tell it turned by where my timing marks were.
I am positive the timing chain and everything went back on ok. I was able to easily turn the engine over by hand and turned it a number of times and timing marks lined up perfect.
Questions:
1) Any initial suggestions on what it could be ?
2) One thought is that when I took the slave cylinder out it was fully extended and I just pushed it back in place to put the bolts on etc... I understand air can get in ? If that is the issue does anyone have any suggestions ?
3) The transmission came out with the engine and it went in fairly easy -- about 90% of the way on before tightening bolt - but could something have jammed - such as input shaft and that is jamming flywheel ?
I am leaning towards the slave cylinder having an issue and not releasing the clutch when starting - anyway to check that ? I bleed it - even though I understand that since I didn't open it up it should be out. I believe though that since the bleeder is before the end that extracts that the fact it opened all the way up means there could be air in the end bu once again I am not sure how to know.
Any advice would be greatly appreciated..already put way too much money and time in it.
Any suggestions at all??? AN update is that I took the starter out and it is shot. But likely shot because the engine wont turn and I persisted.
---- Should I be able to turn the engine by hand (the crank adapter with a breaker bar) with the injectors out ....I was able to obviously easily turn it before putting transmission on and accessory belt etc. ? Or is it most likely something to do with the manual transmission binding against the flywheel ?
Did you ever solve this issue? I have the same problem, gearbox sliped on ok but not all the way, tightened bolts up but didn t like it, now will not turn over, i'm sure I put the plate in correctly
