I have a split drivers side inner boot on the o/s/f drive shaft,I want to replace it and wondered is it a special? is it called a Tri lobe boot??? its the one from the gearbox and bearing support, not the one at the back of the hub.hope this makes sense.
u can get boot kits but cost a ortune better off buying a seconhand driveshaft and either swapping over boots or if in good nick just use knew one go from abot 25 quid the kits go from about 60-90 quid
got the inner GKN tri -lobe boot for £7 new and the outer for £3 from GSF parts so will pull the shaft and fit them both
