Hi there, I’m new to the forum and mini game so hopefully this goes well... I’ve recently purchased a 59 plate Mini Cooper S n14 engine, when performing a rather sharp turn at low speed the oil pressure sensor sends up a warning on screen, however I know there is plenty of oil in... was wondering why this was, any help is greatly appreciated, cheers
you say you know there is plenty of oil in there,, when car has been sat for couple of hours where on dip stick does oil reach to,
Above the circular cut out at the bottom end of the plastic bit on dipstick and below the top of the plastic bit. I believe this is whereabouts it should be?
you say you know there is plenty of oil in there,, when car has been sat for couple of hours where on dip stick does oil reach to,[/QUOTE]
If you've only just bought the car, I think I'd change the filter & oil first.
Maybe go up one grade of oil?
... & see what you've got ...
After all, it is a 9-yr-old car, so a pressure test with a real pressure gauge is simple & not expensive at a garage.
You'll be looking for 50-60lbs psi at normal running speeds.
Discussion Starter #6
Great stuff thank you, well it’s booked in for a full service next week so I will also get the pressure checked, thank you for the advice
Discussion Starter #8
Yes I’ve had diagnostics ran and no fault codes showing, thank you for that article though, be useful if it does brake.
About this Discussion
4 Participants
Isaact7
MINI Cooper Forum
Full Forum Listing
