91 GT with a 5S-FE, needs a new oil pump and head (among other things). Does anyone know if I can just use the oil pump from the Camry engine that was inside it? (99 Camry). I’m putting the original engine back in and I notice the Camry oil pump is slightly bigger, which I assume will give me more oil pressure. Also, I’m guessing that Camry head won’t go with the celica block as the water jacket holes are not lined up?
sxprojects packages
