The oil pressure sensor is right next to the oil filter. Find sensor. Disconnect wire, unscrew sensor, screw in T fitting with original sensor screwed in the end. Screw oil pressure line or sensor for gauge into other opening.DeK said:Hello,
I want install myself the gauges supplementary (oil temperature and voltage). for my MC S, where is the OIL sensor at the motor ?
who have the plan for this sensor ? who must i install this ???![]()
thank for you reponse![]()
The sensor I'm talking about measures the pressure.DeK said:OK for the pressure, and for the temperature ?
i want install the temperature OIL sensor (not pressure), I must look the oil filter![]()
