Hello everyone I am new on this forum, so I've been having an issue with my mini cooper s 09 1.6L Turbocharged.
I had replaced the head gasket cover and seals in the past since oil was leaking and that fixed that issue.
Now the oil light is coming on my dashboard when driving at slow speed or when stoping the car and it continues to come on and off, i drove the car on the highway not stoping and the light wont come on.
I did some basic observations and first thing i did was check if i was running low on oil and everything looks good.
I then replace the oil pressure switch (or sensor) and the light is still coming on and off.
Scanned to see if any codes would come on but nothing related to this issue.
I even try to reset the light on the dashboard but still the same.
I then notice that the crankcase vent hose that goes from the head engine to underneath the manifold was damaged and it looked and sound like air wasn't flowing the way it's supposed to could this be the reason why the light is coming on and off? I also noticed a little of oil on the head.
Im planning on buying it anyway since its damaged to see if this changes anything.
If anyone has had any issues like this i would really appreciate your comments on to how you got this oil light fixed, thanks!
