1 - 14 of 14 Posts
A GinGer ******
Hiya
Get my MCS in March will be putting in my Origin B2 ( Speed Camera Detector) in soon as, just wondering if any of you guys use the same system and where you have mounted it? any pics going
Regards
A GinGer ******
Rakey said:
mine sits right hand corner of the dash under the window, just the two section meet, will take a photo for you;)
Thanks a lot, look forward to it
I've been a little worried about installing it, 19K on a car then start p*ssing around trying to install extra stuff :confused:
Banned
The Origin is a really easy install, if you fit it where mine is all the extra wires hide either under the steering wheel housing, which removes easily and there is also a little cuppy storage area for wires on the right of the dash (have to open the door to see this one;))
All wires hide away easily and tidy, with very little effort:D
A GinGer ******
Have you done the latest update and got the large speedo?
also is your speedo reading always about 5mph to slow? mines does no mather what the speed its always 5mph slower than my cars speedo....
Fairly common for car speedos to under-read. That's why the police normally give you a 10% error factor if you get stopped. The GPS speed comes right from the satellite so it should be the more accurate one.
Banned
yeah did that update this week after I read it on the site:D
I have noticed a difference in speed, and like Stovie said the Origin is more acurate, as I have compared Origin, Speedo and Sat Nav speeds, the speedo is always the one out;)
oh and mine is fitted like Stovies, but I don't seem to have any pics on file:confused:
Apparently the cable coming out the craddle can be moved to the right side to make it even tidier, but I have not tried this yet, might try next week:)
See you in my rear view!!
I think there are some pics in my gallery but they are the same. Unit in the corner and the aerial in the centre of the dash!
Whats this about a large speedo??
Banned
Mini-Monkey said:
Hi Rakey,
Yes it does,I have done this on mine.
But do be careful when you take it apart as some magnets will come out.
Andy.
LOL, I am not known for being careful so might just leave it as it is seeing as it is stuck to the dash:D
thanks for the tip off;)
1 - 14 of 14 Posts
