can an over tightened wheel hub nut cause creaking and knocking sounds??
no not on mini wheel bearings as they are uni hubs ie the bearing part is pressed and and centre bolt dont hold the it together just drive shaft in spines ,, creaking and knocking tends to be bushes maybe drive shaft joint if really bad ,
Ok found out it was the strut mount thanx guys
