1 - 1 of 1 Posts
I've replaced the thermostat housing with temperature sensor, tried to bleed off the coolant but it's still overheating. The relays test well, the fuses are fine. The fan runs if I short the wire going to the temperature sensor. I've tried running the motor with the heater on, but when I open the bleed valve nothing comes out.
1 - 1 of 1 Posts
