if have bubbles from coolant tank then suspect gasket or cracked head at worst, if removing the head for gasket change do the full hog hone the bore fit new piston rings and big end bearings and deffo have all the valves out clean and reseat and new valve stem seals is a must i must of done 20 cars in past year and all run perfectly now link below for idea
www.mini2.com
i got another one turning up tomorrow 2010 cooper s jcw convertible with running issues its done 100k and shows all the signs of age and wear ,, good thing is they respond well to a refresh as long as got good oil pressure 40-80psi
mini one 1.4 rebuild 2008 & 2009 cooper s jcw
pics below has been my day , mini one 1.4 with 94000 miles on it failed mot emissions running very rich and misfire, never had timing chain before and is so far stretched it has destroyed the cat melted a big hole through middle also oil burning stem seals and piston rings, so today removed the...
