I'm going to take a guess that you missed a connector to connect back up or is not really connected or you missed connecting it. Fuel Pressure Regulator not connected.
I'm going to take a guess that you missed a connector to connect back up or is not really connected or you missed connecting it. Fuel Pressure Regulator not connected.Hi, further to my last post and after fitting a new thermostat and removing the inlet manifold to de- gunk the valves, I now after rebuild am getting the above fault. Engine starts then dies.stripped intake off again to check conections, all ok, refitted everything, but no success, same problem.Is there a way to test vrc?.
Any ideas?
