Hi Javars,
How did you establish which sensor was faulty?
Cheers.
Cheers.
Thanks Steve, I'll give it a try.Hi
Ignition on. Select reverse. Put your ear against each sensor in turn. If it's working you can hear a faint tick. No tick = knackered sensor.
Simples !
Steve
No just yourself. Leave it in reverse with the ignition on.Thanks Steve, I'll give it a try.
Presume it takes 2 to do this?? :wink:
Two reasons:Why do you rely on Parking Sensors?? can't you people judge the length of your cars??
The more rubbish the manufacturers stuff into cars the more there is to go WRONG
Not much better with the top down, agree these are essential for convertibles. Plenty of bits of rock to back into round here.Two reasons:
1) The convertible has very restricted vision out of the back with the top up
2) we are not as good a driver as you are
Oh hang on, number 2 is wrong so it must be number 1.
Javars...I had the 10 second long beep when selecting reverse which told me I had a PDC fault, the 3rd sensor from the left was to blame.
It appeared I would need to remove the bumper to replace it but that wasnt necessary, I only had to remove the rubber boot seal at the bottom and take out the two screws that are exposed and you can pull the top of the bumper far enough away to gain access to the sensors
10 mins. Job done !
