1 - 1 of 1 Posts
Hi all !
I have a 2004 facelift r53 Cooper s jcw with a passenger side Headlamp problem.
when you switch the headlamps on the drivers side lamp does the up and down motion and the levels out. The passengers side does nothing, when you remove both the plugs from the headlamps and leave it for around half an hour and the plug them back in the passenger side lamp will work a couple of times and then do nothing. If you remove both lamps and swap them side for side,ie the lamp that did not work on the passengers side now works ok on the drivers side, and the lamp that was working on the drivers side goes up and down a couple of times on the passengers side and then stops! Argh.. sorry if I am confusing anyone ,{I even confuse myself sometimes!!}
does anyone have any ideas?? Thanks. Jim.
1 - 1 of 1 Posts
