I didn't know what you were trying to do.
Have a look here should clear things up
Sea Foam Spray
www.detroittuned.com
"This kit is specially designed for the N18 motors that cannot use the vacuum port on the valve cover like the N14 motors. The N14 motors should use the pour in
Sea Foam. For the N18 motors, loosen the boost tube hose clamp on the passenger side, and using a screwdriver, get under the hose carefully and free it up. Once its free, use the screwdriver again to give you some room to insert the spray adapter. Get the red tube as far in as you can, but makes sure the plastic loop is under the clamp. Reattach the clamp to prevent a boost leak. This is now where you need two people. At an increased idle, 1000-1500 rpm's, spray the whole can into the intake path. Once the can is empty, turn the car off and let it soak for about 5 minutes while you remove the adapter and make sure your boost clamp is tight and back to factory look. Restart the car and run it at an increased idle till all the white smoke has cleared. We recommend doing this outside."
Also some videos on YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
www.youtube.com
If the intake valves are badly coked, this won't help much and needs proper full walnut shell blasting or other blasting substance.
Sea Foam is better used as a maintenance before coking up happens.
