I am installing a parrot hands free kit, and I need a permanent live feed , does anyone know which fuse would be the best to piggyback off
2010 Cooper Clubman
Do you want a permanent live feed? It will be powered on the whole time even when the key is removed.
An ignition live would surely be better. My recollection is that there is only one (maybe two) ignition live feeds in the fuse box. Even things that turn off with the key out are not ignition live. The ECU must be doing some jiggery pokery.
I found it with a multi meter. I forget which one it was.
