21 - 40 of 43 Posts
Mk3 Suspension
Apial,
I didn't get the recall letter that, judging by some other posts, went out. Did you get the recall letter?
Also, as I have a car delivered Sep. (SS+), should I insist on the fix i.e. Did your dealer indicate that all cars should have this fitted, or was it a case that only some of the pre Oct. cars pull, and only the ones that pull need the Mk. 3 suspension?
BMW have been characteristically vague about this, so I wondered what impression you were left with. :rolleyes:
i.e. Should all pre oct. cars be recalled?
J.
Discussion Starter · #23 ·
I can only speak from my limited experience concerning all MINIs produced prior to week9 2002. I personally have driven 4 MINI ONES that have driven with a left pull that was excessive. I have not driven one that did not pull left. It would seem likely that my random sample was representative of what the rest would drive like too.
I am under the impression from my dealer that this left pull has only been complained about by relatively few customers due to its mild nature, usually. Furthermore that all of the MINIs that they had sold upto that point, Dec 2001, were pulling to the left in varying degrees.
BMW are fixing cars when a complaint is received. There will be no recall letter to you. If you are dissatisfied with the steering then it is upto you to complain about it.
At one stage it was necessary for the car to be KDS checked first to see if rectification to the geometry would cure the fault. With so many complaints some dealers appear to be skipping that and just booking the car in for new front suspension. A drive of your car will confirm to any dealer if you need the fix doing.
Take a drive in a March build or newer MINI and you will feel the difference. Check the top of the MacPherson struts to see which suspension type you have. The difference is very noticeable, both in physical appearance and in driving.
I don't expect that BMW will want to talk a lot about this problem. They are willing to rectify cars that have unhappy owners to their complete satisfaction.
Why no recall? They probably built about 70,000 cars with a potentially defective front suspension. Do the math. If you were BMW, would you issue a recall for all of them and lose millions of dollars in the process, or just fix them if the customer complains? If they wait long enough and the warranty expires, they can blame "normal wear" and charge the customer for the new parts. I'll wager a lot of people have the left pull and think it is "normal" or just a problem with the crown of the road, so they live with it. I would suggest anyone contemplating buying a used MINI go to Apial's gallery and print out the before and after photos of the new struts.
I may not have a MINI, but at least I'm collecting a lot of animated GIF's! :D
· Addicted to Speed!!
Sorted!
I was one of the people that thought that the left pull wasn't that much of a problem, but after driving my replacement Cooper, I must admit that my October built Cooper had a left drift problem!! ;)
My new May built MINI drives like a different car!!:D
Apial, your right about the tops of the suspension being different!
Here is a photo from my October built car with the raised suspension tops:
And here is a photo of my new May built MINI. The suspension tops are recessed!
It drives as straight as an arrow. Loose the steering wheel on a straight road and it carries on in a stright line!!
Hi R1,
Glad to hear that your new Cooper is much better. Really pleased for you. Those photos are good, same as my car which must have been built at just the right time Week 9 or 10. After driving a Cooper S I started wondering about my car drifting to the left. I think it is OK and it was probably the Cooper S handling differently becuase it had 17 inch wheels. Anyway I have the newer suspension so don't have a problem.:)
· M2 Bapmaster
The dealer that my car is booked in at for the left pull wasn't even bothered about driving/looking at the car. They just said basically that if i'd complained about it I obviously have it and they booked it in,simple as that:D
Unlike the other dealer that said there was no fix and would need to look at it for at least three hours to see if they could adjust anything:(
Skinny,
Did you go back to the dealer that told you there wasn't a fix and tell them what the other dealer said?
I bet you felt like telling them to **** off.
Good luck, hope your car gets sorted quickly:)
· M2 Bapmaster
Silver and Black said:
Skinny,
I was thinking of doing this but...I thought I shall wait until the fix is on my car. I don't wanna jinx anything, plus that way I can take him outside and say "hay you know those parts that don't exist well there on my car!!!"
i had mine done and its bad
and now it feels very wobbly like jelly around corners and it is higher on one side .
the left hand side rear wheel you can fit 3/4 fingers under arche but on the right hand side you can fit 2 fingers .
so they have highered one side to stop the pull :( what will that do to your tyres and what about the handling its total crap
[email protected]£ed off with my mini
Discussion Starter · #34 ·
The suspension on your MINI can not be correct. The ride height should be the same BOTH sides. I would get it back to the dealer and get them to check that they have fitted the correct spring pair.
FYI on my One the distance from the top of the rear wheel arch to the road measured through the wheel centre is 64cm.
The new suspension,when correctly fitted, is far superior to the original.
My dealer also informs me that there are still some problems being found with post March 02 build cars steering. Realignment seems to fix these cars problems.
Some dealers are reluctant to do the suspension swap. Our other MINI(supplied by a different dealer) is now scheduled to have the steering fix after we threatened to take it to another dealer for them to do. The threat was not idle - we had already been offered it should the supplying dealer decide to be difficult. They would have got the servicing work too. We will see how things proceed.
left-pull in new production cars
Is there any evidence out there that the left pull has been sorted on new build cars. I have driven 2 MCS's with the problem, both Feb 02 build with the left-pull.
I have driven one other MCS which did not have a problem.
The problem was particularly bad on one of the cars, which was quite hard to drive in a straight line. I am now considering cancelling my order and waiting to see if these (and other) problems are sorted.
I just can't afford to be at the dealers all the time.;)
Can anyone explain what the actual problem with the suspension is that causes the left-pull.
Apial,
what was the problem with the airbag light? I had that problem but couldn't quite figure out what the service guy was telling me about a cable. I'm not technically stupid, just not yet fully bilingual. :)
1275
Here in some inside info to the problem. Have a search for what the user "oxfordmini" had to say about the whole problem in the thread named "Bizarre Left Pull Remedy-Official." it is long but it has some good info in it.
Also these two feb 02 S do they have the 17" on and had the dealer fitted the new suspension to them?
I have driven a few late build cars and it is not a problem. Also remember that by design (and law in OZ I think) that cars must drift off to the left at a slow rate, so if the driver falls sleep at the wheel he crash into Skippy and not a truck coming the other way. I drive a Falcon as a company car sometimes and I know this drift to the left as well.
As BMW au is very proactive in fixing this problem on early build cars if it arises. So rest assured it won’t be a problem.
· MINI2 Regular
Left pull fix is excellent
Just had the left pull fix carried out on my SS Plus equipped car. It has transformed the handling, with improved sharpness to turn in. Not only does the car now track straight and true, the suspension also seems more pliant over sharp ridges / mid corner bumps, without losing any of the excellent flat stable body control when cornering or braking. The car also appears more drivable, with less need to correct the steering over variable road angles / surfaces. If you haven't got the Mk3 fix, get it done. It really is worth it - the changes make a great car even better.
· MINI2 Global Moderator
Re: Left pull fix is excellent
Glad to hear you are pleased with it Nick, told you it was worth it :) Hope Broad Oak have shaped up too ;)
21 - 40 of 43 Posts
