hi, my first mini cooper ;), how do i check my power steering fluid, and which make to top up with if needed.
thanks in advance....
The Power steering fluid reservoir is located at the rear of the engine compartment behind the oil filler cap. Method:
Car on level ground, engine stopped.
Remove cap, wipe built-in dipstick with clean rag. Replace cap but do not screw down, check level on dipstick, should be between MIN and MAX marks. Replace cap and secure.
Fluid used is Dexron 11
Hope this helps.
thanks for your reply, my wifes car just had the power steering pump replaced for free by mini :D
