My onboard computer (the one that gives you the temperature, mpg, etc) is playing up. It is either working, flickering or off. Can anyone give me advice on what the problem is or is it one for the BMW workshop? Thanks.
MINI One Seven
Sounds like a job for BMW dealer really, however you could try replacing the fuse. Alternatively check the wiring. However, if the wiring is not at fault, and the fault occurs after changing the fuse, it could be an internal fault in the rev counter trip computer so that would be a job for the dealer - look on minis accessories for the price of a new computer unit and add a bit for labour. Hope that this helps and the repair isn't too expensive.
