Before you change a pulley you MUST fit colder spark plugs. Just use a supercharger pully, using both may well over do it. Remember that more charger RPM means more pressure which means more heat. Your car can easily end up running lean at high revs and melt the pistons. The R53 ECU cannot compensate enough for this, it was never designed to. You would need a remap.
