Today I started the job of changing the valve cover Gasket. All being well it would have taken me 30 Mins..... But OHHHH noooo... You cant get away with just a simple job.
As I un-plugged the PVC blowback pipe on the valve cover it came out in my hand with about 3" of pipe on the end of the clip. I then thought I would do a temporary fix and tape it back together and maybe cable tie some bicycle tubing around it until I got more time to fix it properly with some nice proper rubber piping. So as I was cutting back the mesh cover thats on the pipe another 4" piece comes out in my hand. WTAF
So now I am forced to remove the Intake manifold so I can access the other end of the pipe that has the clip on it so I can change the pipe into a nice rubber one. I loosen all the 5 nuts on the top of the manifold and it loosens but it will NOT come away from the engine block. There must be a bolt on the lower side of the manifold thats holding it ill in place. And the area is so Effin tight I can't see where the bolt is.
Can someone PLease before I set my car on fire tell me where the bolt or nut is or Clip that is holding the manifold in place on the lower side. I have tried with a ladies makeup mirror I have jacked the car up and climbed under it I have looked in via the wheel arches. I can't FIND it...
