vac pipes for brake booster and the fuel tank vent to inlet.. common for the electro valve under the inlet manifold to fail and stay open this feeds the inlet manifold with fuel vapours if faulty causes lean fault codes on 02 sensors, another common issue is pcv pipe work to inlet manifold from rocker cover they split or its a new rocker cover for the pcv valve
