all 4 cylinders level is not for your engine thats for the prince engines in post 2006 cars, yours is tritec early engine this is set at tdc,,, your new timing chain will have 3 coloured links on it the cam shaft sprocket and crank sprockets have same you match up the coloured links to the marks on top and bottom pulleys its that easy,, if its jump teeth chance are its bent valves as both these engine are interference ie pistons will hit the valve if out of time, might get away with a couple of teeth out
