Hello everyone. My brother got a used R53 in pretty good shape overall. Everyhting works as intended except for the cluster lights. We started disassembling and found some burnt cables along the way. It seems this car had a big short and it damaged the lighting cables. We replaced the cables but still no lights.
Checking the voltage on the lights cable line (pin 14 of the speedo) we had 0V so something was wrong with the speedometer.
Disassembled the speedo and found a burnt transistor, the one that connects to pin 14.
The one in question is the transistor TR11 the one that sits next to the pin connector.
Does anyone know what type of transistor is it so I can get a replacement? Because mine is blown and I'm not able to see the specs.
If someone has a picture of a R50/53 speedo electronics so I can check the transistor code, that would be of much help too. I couldn't find anything online, not even a single picture of the board.
Here are some pictures of mine
Thanks!!
Thanks!!
