Hi
I'm having a problem with my front wing wheel arch plastic trim comings off! There seems to be a rubber fitting on the body (wing)that is torn up and this isn't holding the male fitting attached to the trim.
My question is can you buy this rubber part that fitted to the wing? As I can't seem to find it on the internet.
wheel arch clips below, these slot in to the arch and then push on a hole in the body of car,
10x BMW & Mini Bumper, Wheel Arch Lining & Splashguard Clips
BMW MINI INNER WHEEL ARCH LINER FASTENERS CLIPS COOPER S ,ONE,R50 R52 R53 R56
failing this if the plastic arch is broken behind and can slot the clips in a tube of tiger seal link below
Thanks Mike
I have the 1st ones you show slid into the back of the trim but there is like a black rubber grommet fitted into the cars wing, that's the part that's knackered, I will add a photo tomorrow.
I might even just use a bit of that polyurethane sealer that should sort it :)
below link never used these before so pot luck
or do you mean these
