Driving home yesterday the engine light came on. I checked it with a code reader this morning and it came up with the following.
P 0110 - Intake Air Temperature Sensor 1 Circuit. Also P111B.
Took the air cleaner element out to check and found it to be serviceable.
Any pointers on where to look or what to do next would be appreciated. Thanks.
Vident iEasy320
not seen that one before trouble is not all code readers are equal and see all the codes at that sort of price band, think if were me would get car scanned with garage level scan tool to ensure not seeing all the codes as i suspect,
snap on diagnostics or a £600-£1000 autel ,, failing that get yourself autocom cdp plus i know that does see all codes and will code ecu's as well under £50 link below for idea
the above is the double board version so full functions , its garage level at no money i've had one for past 7 years or more and used the hell out of it works a treat
