Just looking for some advice - I have a set of these speakers (brand new in box) as I bought them for another car a few years ago and never got round to fitting them:
Pioneer TS-A131CI 13cm Separate 2-Way Speaker System (300W)
Maximum Output Power: 300 Watt
Nominal Output Power: 35 WAtt
Impedance: 4Ω
Frequency response 28 - 29,000 Hz Hz
Sensitivity (1W/1m) 89 dB
Woofer size (cm) 13 cm
Woofer material Carbon Graphite IMPP Interlaced Aramid Fiber Cone
Tweeter size (mm) 20,0 mm
Cut-out Hole 121 mm mm
Mounting Depth 52 mm mm
Would I be able to install these without too many issues? - anything I should check for?
The original were 4" midrange an 6" midbass You will need to make adapters but they should fit easily. I can't remember for sure but I think they were wired in parallel and both sent a full range signal. Do they come with a seperate crossover?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
MINI Cooper Forum
