Hi...nice to see mike 1967 back!!
Get this ...I take my S to a licensed backyard mech for a clutch rep.....halfway through the job drop by for a peek....I am instantly horrified when I look under hood and see all wiring pulled from ECU and to make matters worse the Batt is still connected...I look at Bozo and say...wtf?....this scares rhe phuk outta me....I leave quickly and leave it to him (and God)...go to pick it up 2 days later, he's just finishing....I try to fireit up and the engine acts like a bad HPFP...fire/stall umpteen times...finally fires if held at 3000 rpm for a minute.....then idles like shit....ENGINE SOUNDS COMPLETELY WRONG. makes about 50hp max....I decide I'm gettin my car outta here!....halfway home.....call tow truck, next day I find broken wire at boost cont sol, also live stream shows no coolant temp...( yup, disconnected at sender) Live stream shows 0.0 short and long fuel trim regardless of engine rpm...throws code .......
Mini Cooper Fault Error Codes - BMW/MINI Cooper Parts
new.minimania.com › Mini_Cooper_Gen_II_OBDII_P...
Feb 1, 2018 — The Society of Automotive Engineers (SAE) developed the OBD II system ... For Generation 2 MINIs: The P code, or Powertrain DTC codes are as follows: ... P3108 - Cylinder 3 High Pressure Injector Low Side Circuit Open. alssso MAF (live) reads o.9 at idle rather than the usual 0.3.....(i'[ve seen this before and I believe it was due to vac leak...can't remember),,,,,the car is going to the stealership tues....anyone care to speculate?....please!!
