Hi all, just joined the forum, typically because we have a problem, my wife's 2012 Countryman's engine blew a couple of days ago. Hoping that someone has heard of the issues before and can use this to guide us on what to do, i.e. repair, replace or cut our losses.
Bit of background, we've owned the car for about 5 years, bought from cooper mini in Norwich as an approved car, low mileage, top of the range for its year.
My wife doesn't do many miles, when we bought it, it'd done 32,000 it's now on just over 50,000. Always serviced at cooper, when the car indicated service required (which I never liked, and reading up looks like a bad move re. Oil changes). Just had its first service 3 weeks ago at a local mini independent specialist.
Anyway, the other day, car started making a strange noise, followed by power loss and misfiring. Wife was about 5 miles from home and managed to limp it home. No warning lights came on at all.
When I got home from work and checked the car, there was no coolant at all in the header tank, and I suspected the head gasket had gone. Tried topping up with just water, as knew it would need to be drained anyway, and it was like pouring water down the plughole. It took 5 X 2 litre bottles of water, without raising the level in the header at all. Checked underneath to see if it was leaking, i.e burst rad or hose, but nothing. Checked inside the oil filler and could see the level rising up above the camshaft!
So the water is pouring straight into the oil side, I'm guessing a cracked block or head?
Has anyone heard of anything like this before with this engine? Is it toast?
Thanks and regards,
BertyH69
Thanks and regards,
BertyH69
