I found the problem. When I pulled the radio out, there was a wire that had become disconnected. I assumed it was the control wire, so I re-connected it and that solved the problem.
The story behind this radio is that when I bought the car a few months ago, it had a Sony head unit in it with an amp in the hatch area. The head unit didn't fit all the way in as there were RCA plugs that stuck out of the back of the unit.
I wanted the original look back, so I got lucky and found one at pick-n-pull from a 2003 model like mine.
I had to re-do all the wiring back to original because whoever installed the Sony unit had spliced into the original wiring to adapt the unit.
After all that, the radio worked first time and had for months. What I suspect is that the radio received the correct signal on initial startup, but between then and now the wire came loose. When I disconnected the battery to do the thermostat housing replacement it did not get the signal and went into disable mode. Once the wire was fixed, it got the correct signal and is now working.
Hope this helps someone in the future.
