I took in the 2015 f55 in because the real time traffic flow is no longer working. They told me they reconnected the antenna by removing the head unit. First, the service advisor didn't know what real time traffic updates were. Second, I didn't believe the method they resolved the problem. I checked before leaving the dealer and no traffic updates were being received. I've had the car for a year and use the feature daily to go around traffic. I thought the rtti information was received over the air but the antenna checked it fine. I have disabled and enabled the traffic updates, flow, but had no luck.
Thanks in advance-----
-V
Get a new Radio,seems your either tuned into a station that does not carry/ transmit TRAFFIC REPORTS or the Traffic Reports is switched off...ie..press i the display should show "TRAFFIC"
I enabled and disabled the traffic reports and nothing. How do I tune it to a station that carries the reports. On a side note they replaced the evaporator unit because mildew smell was coming out of the AC. When they replaced it I could no longer use the USB port so I had to take the car back in. This time they told me the lead to the antenna behind the radio was disconnected. I'm starting to think they caused all these issues when they repaired the AC.
-V
