Did you ever get this sorted @Egg1000 ? I have the same problem, and the same issue trying to remove the central cluster.
Yeah, I fixed it in the end. Initially took it to Halfords to ask them to replace the bulbs. They made it look easy but stagnant water came out! I contacted the guy I bought it off and he replaced it for me. However, we still had issues with it, so I removed the LH cover with only two screw's and found the back is relatively easy to remove, however the clips that release it aren't the large parts, they're the tiny lip of plastic next to them, once you realise it's not the obvious clip, the others squeeze together quite easily. Hope this helps.Did you ever get this sorted @Egg1000 ? I have the same problem, and the same issue trying to remove the central cluster.
