rear washer & wiper not working
1255 Views 3 Replies 2 Participants Last post by  Er3bas
Hello everyone, first I can say I did look in to alot of threads you have here but just did not find the solution for my case. I am truly sorry if there is and I did not find it can you give ne the link?
So here is my problem:
The rear washer and wiper are not working both.
What have I done so far:
For the wiper - I have tested the motor by providing an external power it moves as it should.
For the washer: I have taken out the washer from the water tank and gave it some external power to one and other side seems fine and its pushing water. ( btw the front works fine )
Then to see if the thing is not clogged like a lot of you suggested I swapped the front and back hose water sides and fluid went to the back fine.
I went over the fuse box and apparently where the motor fuse should be its emty( f30 if I remember this correctly )
I did open the hood and found 2 relay for wipers ( I think they both front ones, for speed and turn on/off)
So guys would gladly appreciate if you can give me any pointers, currently checking wires in the boot but not too sure if I will be able to detect
Sincerely thank you for your help straight away and for waisting your time trying to help me
I would suggest looking at the wires in the concertina that carries wiring into the hatch. Look for damaged wires.
2
Have done that and I believe I might be in a pinch. There is no problems untill this plug in the fuse box
278240
278241
Also connecting external power to the + of wiper it gives Short-circuit
