Hi
Hopefully an easy one, how do I remove the trim piece above the keyslot? Its the piece of trim that is usually colour-coded (in mine Piano black) - Its the same
Its the brushed aluminium one in the attached picture (although that is LHD, and my car is RHD you should get the idea!)
Adam
Totally maniacal!
Hi Adam :)
If you adjust the steering wheel so its as low and as close to you as poss (to give you a bit of clearance behind it), and then just pull the trim towards you it should come off without too much force.
Worked for me anyway :D
