Hello! Just wanted to ask regarding removing racing stripes and installing a new one.
I wanted to replace a part of the racing stripes on the bonnet because there was an approx. 1 inch scratch. on one of the 4 stripes. I went to the dealer and asked what they could do and the service personnel told me that its going to be $700(with labor) to have them removed, and replaced with a new set. I then wanted to talk to the technician to ask what exactly will be done which is worth that much....just wanted to clarify if what the tech said was true.
1) To remove the old decal they need to prep the old one with chemical and then a heat gun to remove it without damaging the paint.....if I try it, like what is shown on DIY videos, I can possibly pull off some of the top coat and damage the paint
2) Once removed, The paint should be thoroughly cleaned and then prepped for applying a new decal using chemicals and buffing.
Since I only needed 1 of the stripes replaced, I asked if they could just do the one that is damaged...
3) If you will not replace the whole set from front to back, they wont look the same even if they have the same brand.
Any advice? Thanks
I saw on shopminiusa.com one side bonnet strip is $103 and one side boot stripe is $72, so a complete set is $360.....on the website is shows an extended play time(warranty) for original accessories....i guess bonnet stripes is not covered. I just got my mini late last year(less than 6 months)
Any advice? Thanks
