Mini Nut
Hi
Has anyone removed their rear seats from their mini......
If so, how involved is it and how did you do it. I had a quick look at lunch but couldnt see how to do or where they are screwed down.
Any advice?
Cheers :)
MMC Member
Looking in from the boot down at the bottom between the two seats there is a bolt. Lower the seats and remove this bolt then flip the metal piece it holds down up. Then raise each seat to about 45 degrees and they should slide out. They are keyed which is why you have to raise them.
