Senior Clubber
Hi
Having played around with a few different settings on my KWv2 coilovers.
Originally I think I set them too low as I ended up with massive negative camber on the rear and the ocassional vibration when accelerating.
Latest setting seems to have cured both these issues
With -30mm on the rear and - 40mm on the front I think it looks about right.
My thanks to Lohen who have persevered with my changes without complaint.
Boosted
Need to fit some wheel spacers to fill the arches a bit! :) Looks Good!
Senior Clubber
The ride is a lot firmer than stock but not so much that my fillings will fall out.
I guess that is a matter of personal taste/tolerance.
Beauty of V2's is that you can set them to your preference -- 20 clicks from soft to hard.
Currently I have the rears set to +12 clicks and the fronts to +10
Fronts are easy to change but the rears require that the unit is dropped from the car (3 bolts) to access the adjustment screw
