so
gf mini 2005,cooper conv had passenger window not working so i tried the bang on the door trick.it didnt work...
so i proceded to take the door card off,i couldnt see any cables pulled off inside so checked the windows and roof,
sunroof went back as normal,rear windows dropped too,then nothing,i disconnected the battery hoping to reset,
now this is where the problems start,on reconnecting the battery and turning the ignition on,the lights turn on without turning on via the stalk,the sunroo opens but wont go into full roof open and the rear windows wont go up,im proper in a fix.
there is no flashing light for the roof and i cant see whats happened with the rear windows or roof,iv checked all the fuses and they seem fine,
any suggestions would be greatly appreciated
How old is your battery? still the original?
It might be its just low on voltage and starting to fail?
A failing battery can cause all sorts of electrical gremlins on the MINI.
Get the garage to do a voltage drop test on it?
