Has anyone been able to find out if the rubber mat/coin holder that lives just below the handbrake in 05 MINI's is available as a retrofit?
Checked with my local dealer but they couldn't find anything for it :( .
MINI2 lurker
In theory it should be able to be fitted, althought the only real complication might be the tyre pressure indicator.
personally I dont like it and use the utility tray as a coinholder, its quite deep and holds all the £'s which im happy with.
Had a look at an 05 in the dealers today and Mini Blake is quite correct. The position of the tyre pressure switch has changed to the side so doesn't look as if it will be a straight forward swap.
Ah well, thats the cubby hole now fitted and the chrome interior on order :).
