Hello all, I bought some meguiars scratch x today to try and remove some light scratches from the door of my beloved Swiper. I used a good cloth and rubbed it in but it doesnt seem to have touched the scratches, what am I doing wrong as people seem to like this product. I have always used meguiars polish/wash on him.
Any help would be appreciated as being BEP means the scratches show,although you cant feel them.
Derv? Nein Danke.
i've just used it for the 1st time and found it takes ALOT of time and elbow grease to remove the lightest of marks. I was really surprised at the complete lack of abrasive in ScratchX.
I ended up using a rubber eraser to work the ScratchX into the marks on my paint, which worked very well. Its lack of abrasive content makes it miles kinder than traditional T-cut but takes longer to achieve satisfactory results. Another tip a body shop showed me was to use a pencil with a rubber eraser on the end to work on a small scratch and minimise the area of paint worked on and concentrate the pressure on the tiny area that needs attention.
Thanks for the advice am working on it!
Will let you know if I have any success.
A Total Mini Convert
I found that the Auto Glym paint renovator was slightly more abrasive, so when I get a more stubborn scratch I use the Auto Glym first and then finish of lightly with Scratch X.
dyno-mite, might not....
found my scratch x, deffo not up to scratch lol
but will give your tips a go, perhaps better second time around
cheers
MINI2 Veteran
hmm, out of the two, Glym Paint Renovator is probably more abrasive as said.
Try that first, then rebuild the wax on the car.
Scratch x requires a nice dollop, and a lot of elbow grease!
Will Johnson
for what its worth - german paint is very very hard... ScratchX (and most other brands) of hand scratch removal polishes will really really struggle... That said, i found a small mark on my dark silver MCS and just had to get rid of it....
Using my UGM pad i applied about 5 layers.... while it looked like it was working it wasnt really having the effect i know it can produce (used to have a black 206....)
I then cracked out the Megs G220 with a Sonus #3 pad and began to machine polish the area... a couple of applications later and the mark had all but vanished! hurrah... hope that helps... extreme i know, but does the job!
