Its probably the same now as when I got mine, and thats that you get a booklet entitling you to so many services, and just like Tesco's when they're gone they're gone.zyo said:Is the deal on the tlc 'UP TO' five years or 50,000 miles free servicing or is the 50000 miles or five years fixed?
It is. I think I've got 5 vouchers in mine - not checked it though.m1les said:Its probably the same now as when I got mine, and thats that you get a booklet entitling you to so many services, and just like Tesco's when they're gone they're gone.
No way!bigtent said:Anyone else do less than 25miles a day (or none), and noticed the service countdown just knock 25miles off per day wether you driven the car or not?
For TLC you will have 3 service vouchers and 1 brake fluid voucher.D1N0 said:It is. I think I've got 5 vouchers in mine - not checked it though.
The scheduled services are 10000, 25000 and 40000 miles. It's made quite clear that you get 3 services, so in general that means that you won't have to pay for one until you have done more than 50000 miles - or 5 years at 10000 miles per year.KenL said:You are not likely to get past 40k miles
Hey Sebby* to find out how many days to having your brake fluid changed you have to press the button on the speedo when it is displaying the miles to next service after startup. Hope this helpsSebby* said:How do you know when your MINI needs its brake fluid change? I know that the oil inspection is stated (I've had my MINI for 11 months now, it has done around 7500 miles, and the inspection is due in around 1500 miles), but what about the brake fluid?
Cool, thanks, I didn't know that.BAZil said:Hey Sebby* to find out how many days to having your brake fluid changed you have to press the button on the speedo when it is displaying the miles to next service after startup. Hope this helps![]()
I am indeed.BAZil said:PS. Are you the same sebby* from digital spy?
Yes, you can take your car to any MINI dealer.BAZil said:Also does anyone know whether you can visit any MINI dealership for warranty work because my outside temperature reading is displaying around 10 degrees higher than it should be and my dealer I purchased my car from is further than a local MINI dealer (Henry Bros)
