You can change the parameters of any weapon if you load the console up whilst playing.
To do this find the shortcut on your start menu for half life 2, right click on the icon and click properties. Add "-console" to the end of the command line. Now when you load HL2 and start playing tap the key above the tab key and the console will appear.
Type this to activate the cheats: sv_cheats 1
Changes the radius of the cone used to pick up objects physcannon_cone #
Changes the length that objects can be pulled from physcannon_tracelength #
Changes how quickly objects are pulled physcannon_pullforce #
Changes how large pulled objects can be physcannon_maxmass #
Changes how hard you propel objects physcannon_maxforce #
Sets developer mode to on/off/verbose (0-off, 1-on, 2-verbose) Developer #
Enables mouse look +mlook
Give weapon (Input weapon name in place of #) give #
Shows Crosshairs hud_quickhelp/text? 1
Adjusts size of the weapon you're carrying (54 = default) viewmodel_fov #
Execute a script file (Input filename in place of #) exec #
Toggle HUD display On cl_drawhud 1
Toggle HUD display On cl_enablehud 1
Shows FPS Rate cl_showfps 1
Creates an NPC npc_create
Creates an NPC (Aiming away from player) npc_create_aimed
Toggles Picker mode on picker
Move player to specified origin setpos
Snap players eyes to a specified pitch yaw setang
Set Gravity (Add number in place of #) sv_gravity #
Set Minimum Stopping Speed on ground (Add number in place of #) sv_stopspeed #
Set World Friction (Add number in place of #) sv_friction #
Sets bounce multiplier for physically simulated object collisions sv_bounce #
Sets Maximum Velocity of any moving object (Add number in place of #) sv_maxvelocity #
Set Vertical View when eyes are near water plane. sv_waterdist #
Change the density of air. (Add number in place of #) air_density #
Set length of confusion/ear-ringing effect(Add number in place of #) dsp_explosion_effect_duration #
Toggle bounding-boxes debug mode on/off red - ignore damage, white - respond to damage, green - health) prop_debug
Toggle reporting missing .wav files for sounds sv_soundemitter_filecheck
Limit the number of texture units. (Add number in place of #) (0=Default) mat_numtextureunits #
Damages player by whatever variable you input as # Hurtme #
All Weapons impulse 101
Spawn a Jeep impulse 82
Invisible to NPC's notarget
Ability to walk through walls (Server Side Only) noclip
Displays Map listing maps
Load Map (Input title in place of #) Map #
God Mode (Server side only) God
Reduces Health buddha
Grunt-O-Matic impulse 76
Recieve a Shotgun give weapon_shotgun
Third Person View thirdperson
First Person View firstperson
See through walls mat_depthbias_normal 1
# is new max ammo for submachine gun sk_max_smg1 #
removes the item or NPC pointed at impulse 203
removes all shadows (a 0 restores them) mat_fullbright 1
gives infinite power for sprinting, etc. sv_infinite_aux_power 1
brings up position display in top right of screen (0 removes it) cl_showpos 1
# is new damage value for SMG grenades sk_plr_dmg_smg1_grenade #
# is new damage value for submachine gun sk_plr_dmg_smg1 #
# is new damage value for RPG rockets sk_plr_dmg_rpg_round #
# is new damage value for grenades sk_plr_dmg_grenade #
# is new damage value for crowbar sk_plr_dmg_crowbar #
# is new damage value for crossbow sk_plr_dmg_crossbow #
# is new max ammo for crossbow sk_max_crossbow #
# is new max ammo for hand grenades sk_max_grenade #
# is new max ammo for pistol sk_max_pistol #
# is new max ammo for RPG sk_max_rpg_round #
# is new max ammo for SMG grenades sk_max_smg1_grenade #
unlocks chapters 1 thru # (15 is end credits) sv_unlockedchapters #
# is new damage value for pistol sk_plr_dmg_pistol #
# is new damage value for .357 Magnum sk_plr_dmg_357 #
# is new damage value for Pulse Rifle sk_plr_dmg_ar2 #
# is new damage value for shotgun sk_plr_dmg_buckshot #
toggles enemy AI on/off ai_disable
change skill level (# = 1, 2, or 3) skill #
# is new max ammo for .357 Magnum sk_max_357 #
# is new max ammo for Pulse Rifle sk_max_ar2 #
# is new max ammo for Pulse Rifle energy orbs sk_max_ar2_altfire #
# is new max ammo for shotgun sk_max_buckshot #
Spawn an Air Boat impulse 83
Enables ragdolls that don't clip through each other, but stack realistically on one another. cl_ragdoll_collide 1
.357 Magnum weapon_357
Overwatch Standard Issue Pulse Rifle weapon_ar2
Pherapods weapon_bugbait
Crossbow weapon_crossbow
Crowbar weapon_crowbar
Fragmentation Grenade weapon_frag
Zero Point Energy Field Manipulator Gun weapon_physcannon
9mm Pistol weapon_pistol
Rocket-Propelled Grenade Launcher weapon_rpg
12-Gauge Shotgun weapon_shotgun
Submachine Gun weapon_smg1
Increases pellets fired from each shotgun shell. 100 works well. 1000+ and it lags. sk_plr_num_shotgun_pellets #
Raises your max number of shells to that number. sk_max_buckshot #
Raises damage done by each pellet. sk_plr_dmg_buckshot #
Increases suit charge by 15 points. give item_battery
