Hi Guys,
From now until christmas we will be offering both GTT 220 + GTT 230 coversions with a 15% off promotions offer.
GTT220 ecu remap + optimised bypass valve + high temp iridium sparkplugs + GTT supercharger pulley + shorter 'stickier' drive belt + GTT twin bearing idler pulley. + GTT 'cold ram' induction system also included is a very nice stainless steel badge with blue engraving on the engines rocker cover donating the conversion fitted.
Normal price £995 +vat fitted
promotion price £845.75 + vat Fitted
GTT230 ecu remap + optimised bypass valve + high temp iridium sparkplugs + GTT supercharger pulley + shorter 'stickier' drive belt + GTT twin bearing idler pulley + GTT 'cold ram' induction system + GTT large top mount 16 tube intercooler c/w GTT diffuser + GTT exhaust re-route pipe also included is a very nice stainless steel badge with blue engraving on the engines rocker cover donating the conversion fitted normal price £1645 + vat fitted
Promotion price £1398.25 + vat fitted
Plus we will Check tyre condition +report
Check tyre pressures, adjust as required
Check all wheel bolts for tightness (often very loose!!)
Check oil level (often very low !!)
Check coolant level + free top up if required
Check + free top up of windscreen & headlight washer fluid reservoirs
Check power steering fluid level + free top up if required
Check brake fluid level + free top up if required
Visual check of brake disc & pad condition
Full diagnostic fault code readout & re-set
Engine bay cleaned & valeted (by hand -no steam cleaner!) ‘Tender love & respect’
Full road test & report
Quite possibly the most popular and proven 'complete conversion packages' on the market. It has proven outstanding for its long term 100% reliability. These conversion can be fitted by us in a day. :smile:
To book in for one of these conversions call us on 01258 455545 and quote the pomotional
offer. A £100 deposit will be required to book an allocated day. fitting dates start from 10th November..
Best Regards GT Tuning:smile:
