1 - 9 of 9 Posts
Hi Guys,
We have another promotion offer for you on our 'GTT Cold Ram Induction Kit'
Normal price £169 +vat
Promotion price £139+vat
This product is included in GTT 220 conversions and above. True 360 degree rolled edge (CNC turned from solid) Ram-Pipe. This is expensive to produce and quite unique as other companies (if they even use a Ram Pipe at all!) use a 'spun alloy' ram-pipe that will always have an 'undercut' lip which cannot allow air to be drawn in from behind the pipe. This is as a poor substitute for a true machined fully round section lip. Our Ram-Pipe will pull air from all directions including behind the pipe, avoiding undesirable air currents at the trumpet entrance. Notice also the Ram Pipe entrance is positioned well out into the airbox, if it were flat against the airbox face it could never draw in air from the rear! By comparison a round hole at one end of the airbox is about as bad as it gets, we know as we've tested them on a flowbench!
* True cold feed using a larger (note the angled side) 'twin skin' upper airbox to shield away the heat from the adjacent hot exhaust manifold This increases airbox volume by around 25% over all other designs that seal against the bonnet underside. The 5mm air gap between the skins gives a superb thermal barrier. After a hard run the Ram Pipe remains ice cold to the touch. The upper airbox/heatshield is anodised in an attractive blue finish for good appearance and longevity.
* Optimum filtration, with negligible pressure loss is achieved using a large corrugated cotton gauze cylindrical filter of over 5" dia (others use 4" max) enclosing the Ram-Pipe. This is effectively(almost) invisible to the incoming air, which is also drawn in through the end of the cylinder through a 'twin layer gauze filtering screen' .This again is much preferable to a capped end. This is all held and supported to the airbox with 4 stainless steel springs, allowing simple dismantling to clean. The air feed is supplied to the filter from the original front intake plus a second and more significant feed from the scuttle area at the base of the windscreen. This is a natural high pressure zone giving the GTT airbox a relatively undisturbed high pressure zone to 'draw' from. For maximum performance potential a neat and tidy 2 inch diameter hole should be made in the 'plastic divider' between the scuttle area and engine bay (or the panel removed). Incidently a small funnel shoved into the outside airstream will not achieve good flow. Our system can be removed or re-fitted in 5mins for dealer servicing if required!
Airbox should be as large as possible (with our system the scuttle area effectively becomes part of the airbox volume too) with high pressure cold air feeds. A true rolled edge Ram-Pipe should be positioned with its entrance typically extending half way out into this airbox. GTT design fulfills all these fundamental design criteria and more! The best induction kit for the MCS by far.......... GTT 'COLD RAM' INDUCTION SYSTEM!
(available in blue or black, special colours £10+vat extra)
To order our Cold ram Induction Kits call us on 01258 455545 and quote the pomotional offer.
Best Regards GT Tuning:smile:
Hi Chaps,
Got my red painted kit this morning. Cheers, it looks like a very well made bit of kit and should match my Chilli red MCS perfectly :)
One question, the fitting instructions recommend cutting the holes in the divider panel while it's in-situ; as I dont really want to get plastic swarf everywhere or even introduce my dirty great big hole-saw to the engine bay, how easy is it to remove the panel so I can drill it away from the car?
Thanks, Paul
hi Paul, very easy,first remove entire airbox to gain access to the airbox 2 locator pins underneath, unscrew these 2, then a further 3 screws on the upright face, pull back rubber trim and lift out.
Best Regrds Roland GTT
Roland I am thinking of getting one of these kits what is required to fit them? Do you need any other pipes etc? Can a novice like me fit one?
Thanks, Dave
Discussion Starter #9
Hi Dave,
Even a novice like yourself should have no problems fitting our cold ram induction kit, which is very straight forward to fit and comes complete instructions. There are no other parts required when fitting .just the tools to do the the job....
Best regards
Roland GTT:)
1 - 9 of 9 Posts
