1 - 1 of 1 Posts
Hi Guys,
Anyone who has our GTT220 or GTT230 conversion fitted between 1st and the 15th octobter 2009 will have the chance to have our GTT Aerobox Strutbrace supplied and fitted for £50 +vat.. :eek:
normal price £219 +vat
The GTT Aerobox Strutbrace is without doubt the daddy of strutbraces for the Cooper S, GP, Cooper & One. The crossbar being machined from a solid billet of high tensile aluminium for ultimate rigidity. The welded ends are joined by a weld run of 225mm long at each end!
Whereas other braces try to prevent movement in one plane the GTT brace stops flexing in all directions; Tension, compression, twist ,lift and any combination of these forces , allowing the cars suspension to work properly. The difference in handling has to be experienced to be believed. With stock or JCW air boxes fitting time is under 10 minutes. Looks (and stays looking) stunning .Comes c/w stainless steel GTT badge.
In summary this has to be the best (and most cost effective) handling upgrade available. Standard colours are powder coat black or powder coat clear (GTT Patina).
GTT220 ecu remap + optimised bypass valve + high temp iridium sparkplugs + GTT supercharger pulley + shorter 'stickier' drive belt + GTT twin bearing idler pulley. + GTT 'cold ram' induction system also included is a very nice stainless steel badge with blue engraving on the engines rocker cover donating the conversion fitted
price £995 +vat fitted
GTT230 ecu remap + optimised bypass valve + high temp iridium sparkplugs + GTT supercharger pulley + shorter 'stickier' drive belt + GTT twin bearing idler pulley + GTT 'cold ram' induction system + GTT large top mount 16 tube intercooler c/w GTT diffuser + GTT exhaust re-route pipe also included is a very nice stainless steel badge with blue engraving on the engines rocker cover donating the conversion fitted price £1645 + vat fitted
Plus we will Check tyre condition +report
Check tyre pressures, adjust as required
Check all wheel bolts for tightness (often very loose!!)
Check oil level (often very low !!)
Check coolant level + free top up if required
Check + free top up of windscreen & headlight washer fluid reservoirs
Check power steering fluid level + free top up if required
Check brake fluid level + free top up if required
Visual check of brake disc & pad condition
Full diagnostic fault code readout & re-set
Engine bay cleaned & valeted (by hand -no steam cleaner!) ‘Tender love & respect’
Full road test & report
Quite possibly the most popular and proven 'complete conversion packages' on the market. It has proven outstanding for its long term 100% reliability. These conversion can be fitted by us in a day.
To book in for one of these conversions call us on 01258 455545 and quote the pomotional offer. A £100 deposit will be required to book an allocated day.
Best regards
Roland GTT:)
1 - 1 of 1 Posts
