The speedo on my mini cooper s has just stopped working all of a sudden, the fuel gauge and coolant temp still work, and also i have tested the dials and they are working perfectly.
Is there a plug on the gearbox for the speedo drive? car is a 2003 model.
Similar thing happened to our 03 with CVT. The odometer, trip meter, fuel and temp are all working but the speedometer needle didn't move.
After taking out the corresponding fuse in the footwell, I took the unit out and practically disassembled the speedometer cluster.
The speedometer needle was taken out and the odometer unit was reseated on the board.
Put it back together and the speedometer needle was working again.
Had the same issue with my 07 plate R52 i removed the speedo and freed the needle which was stuck now working
