CNred said:
I want to get some spot lights for the front of my cooper. But i am confused on which ones to get. I dont know if i want 2 or 4. I have heard the that 4 realling drains the battery. I was also wondering how hard it would be to make the lights turn on by switch like where the windows are at?
i dont think having 4 lights would really drain the battery. what were you planning on doing with them anyway? While you're driving having the lights on shouldn't do anything to your battery... unless of course you have some monster 10,000 watt stereo system in your car draining the hell out of the battery.
Theres another thread where i posted some info, but to repeat...
The dealer installed lights are connected to your high beams. so if you dont have your high beams on, the spot lights dont turn on. Also when you have your high beams on, the fogs lights turn off. its kinda lame.
They installed a switch to turn on the spot light. it goes (if you're in a Left Handed Driving Car) on the knee bolster by your steering column closer to the door. if you look now, you should see a small rectangular plastic piece that pops off. thats where the switch goes.
I popped off the bolster to see how its connected and its a single push button switch and has 4 wires coming out of the plug. It seems a bit complicated the way the have it set up. But yes, im pretty sure if you do some simple re-wiring you can have it connected to the center cosole switches, assuming you have an extra spot for it.
Im a bit scared to take apart my car still since i only have 1500 miles on it and still trying to figure out what else i need to get fixed. (Brought it to the dealers once already
but in theory, it should be relatively easy to rig up the wires. its just some time consuming effort thats required.
