SS and SS+
1400 Views 10 Replies 6 Participants Last post by  Cooper76
does anyone know the exact difference between ss and SS+? Dampers? Roll Bars? Springs? how can you tell the two systems apart by looking at them?
i had a look on the search but seemed to lose myself in people deciding which is best, i wana know whats different.
My dealer said there is a database with the spec of every mini as it left the factory. is this true? where can i find it? was he talking what some dealers are good at?? it would be interesting to know what has been added since it left the factoy.
1 - 11 of 11 Posts
Front Bar:
One 16mm 31 35 6 757 071 w/ bushing 31 35 6 757 069
One or Cooper with SS 22.5mm 31 35 6 757 072 w/ bushing 31 35 6 757 146
Cooper or MCS with SS+ 24mm 31 35 6 758 301 w/ bushing 31 35 6 758 302
Rear Bar:
One none
One or Cooper with SS 16mm 33 55 6 754 818
Cooper or MCS with SS+ 17mm 33 55 6 754 819
same bushing for SS and SS+ rear bars
Struts:
One (standard suspension) - 31 30 6 759 243/244 (F=...243/R=...244)
One or Cooper with SS 31 30 6 759 245/246 (F=...245/R=...246)
(Cooper or MSC with SS+ 31 30 6 759 247/248 (F=...247;R=248)
Springs
For the One, depending on overall weight, with standard suspension:
31-33-6-756-641 or -642 front
33-53-6-756-652 or -653 or -654 rear
One with sport suspension:
31-33-6-756-646 or -647front
33-53-6-756-657 or -658 or -659 rear
For the Cooper with SS : (choice depends on vehicle weight with options chosen)
31-33-6-756-645 or -646 or -647 front
33-53-6-756-657 or -658 or -659 rear (in usa only -658 or -659)
For the Cooper with SS+ : (choice depends on vehicle weight with options chosen)
31-36-6-758-310 or -311 or -312 front
33-53-6-758-354 or -355 or -356 rear
For the Cooper S : (choice depends on vehicle weight with options chosen)
31-36-6-758-311 or -312 front
33-53-6-758-356 or 379 rear
From: http://www.mini2.com/forum/showpost.php?p=730037&postcount=2
thanks
looks like ill be under the car with some verniers to measure my bars.
I have just bought a Cooper and went for SS, do i get SS or SS+? I only saw one option.. :confused:
-Rob
-Rob
SS+ is offered with the Chilli Pack and you have to Specifically ask for it to be fitted, otherwise it will be SS.
Bugger!
some people recon ss is better, depends what roads you drive on? You may pref abit of comfort but i like mine HARD!
i didn't realise there was a slight difference in rear springs between a cooper with ss+ and a cooper s.
ss+ is only uncomfortable on poor residential roads - can't say i notice a problem elsewhere.
I'm quite annoyed, i thought i had a Cooper S in all but engine, but now my little Mini is just an in between! :(
I'm going to go cry myself to sleep..
-Rob
I Wouldn't worry about it-There is not that much difference :)
-Rob
Is yours in production yet? If not, there is still a chance that you can have it changed!!!
1 - 11 of 11 Posts
